Are there vent holes between sump and rocker head on G16A?
npjrogers@btinternet.com
Post by npjrogers@btinternet.com » Fri Mar 22, 2013 11:06 am
I have an 8v Santana Vit that is developing crank case pressure leading to an oil leak from the sump oil pan. With the dipstick removed the crank vents and does not leak. I have removed and cleaned the PCV.
Is there a vent hole or holes running through the block that might be blocked leading to a buildup of crank case pressure?.
The valve cover is venting ok. I have vacuum at the oil filler cap.
There was a huge amount of crud and rubbish under the valve cover when I removed and cleaned it.
Really appreciate any advice
Nick
Belfast
Santana vit 8v single efi soft top 99 85k miles
Re: Are there vent holes between sump and rocker head on G16
Post by ScottieJ » Fri Mar 22, 2013 3:40 pm
Have you checked that all the sump bolts are torqued up? have you fitted a new sump gasket?
Post by Darrell » Sat Mar 23, 2013 7:58 pm
"Are there vent holes between sump and rocker head on G16A?"
Yes :thumbup:
They are there to allow the oil to drain down to the sump.
There's quite a few and if they blocked you would have serious oil pressure loss, so I assume they are fine.
Post by npjrogers@btinternet.com » Sun Mar 31, 2013 12:05 pm
Thanks for all yr advice.. I understand that I dont have a gasket on this model of g16a. I think I will RTV it.
Nick
Belfast
