Moving The Front Axle Forward
Famerbennie
Post by Famerbennie » Sun Mar 24, 2013 8:30 pm
Hi All Can Anybody Help With Moving The Front Axle Forward?
dannytrigger
Re: Moving The Front Axle Forward
Post by dannytrigger » Sun Mar 24, 2013 8:35 pm
i have read that you can re drill the location hole on the axle and on the clamp plate to move it forward an inch or so. havent tried it myself but looks straight forward
Post by ScottieJ » Mon Mar 25, 2013 7:16 pm
Yes you just re-drill the spring perches and Ubolt plates 25mm back from the existing spring pin locating holes,
With stock springs it should effect your caster enough to worry about but if running lift sprigs that have a lot of arch it will give you a degree or so more positive caster, but that's not really much of a problem.
You will need to completely remove the front axle to do this, but that's an easy job.
Famerbennie
Post by Famerbennie » Mon Mar 25, 2013 7:37 pm
So You Just Re-Drill The Hole In The Spring Perches, Nothing Else?
dazerede
Post by dazerede » Mon Mar 25, 2013 7:53 pm
4” calmini lift kit :)
Post by ScottieJ » Mon Mar 25, 2013 7:54 pm
The perches and U-bolt plates need to both be redrilled, sorry just edited my last post.
muddymesser
Post by muddymesser » Tue Mar 26, 2013 9:22 am
but be careful . . . if you go too far your steering bars will touch/catch on each other . . . like mine before bump stops :oops:
justaddmud
Post by justaddmud » Tue Mar 26, 2013 6:51 pm
not to mention you will need a prop spacer as well.
holes were 14mm (had to buy one special)
Post by ScottieJ » Tue Mar 26, 2013 6:55 pm
To be honest I don't think a prop spacer is really necessary unless you are running lift springs, there should still be more than enough spline engagement and no issues with the steering if you only move the axle 25mm
newmanrob
Post by newmanrob » Sat Apr 13, 2013 4:11 pm
How much spline engagement is enough?
