Help needed engine conversion troubles
Has any one done a vitara conversion on an sj and used the electronic ignition distributer? Swapped engine over changed distributer for my old one from 1300, can get to run but can't get timing right distributer end?????? Help please
Re: Help needed engine conversion troubles
Do you mean there isnt enough movement to get the timing correct?
If there isn't enough movement on the distributor pull it out and move it round a tooth.
Cobbled this together...
- Distributor installation.jpg (398.07 KiB) Viewed 5685 times
All 413s have electric ignition, only the 410s had points.
Was the 1.3 carb'd? Or SPI? Did you not get the dizzy with the 1.6 if so why not use that?
right thanks for the in put guys mine is the 1300 spi electronic ignition the vitara injection engine dizzy has 5_8 connectors on it so no use, we un did the distributer nut so we could move it more still no good so we wired up a coil and dizzy but now no spark so going to try another dizzy
Is this the same SJ that Holly was asking me for advice about on Facebook by any chance?
If so how's it running now?
And now your talking to me lolScottieJ wrote:Is this the same SJ that Holly was asking me for advice about on Facebook by any chance?
