props
damo
props
Post by damo » Wed Apr 03, 2013 7:22 pm
any one know if the front and rear props on the 413 are the same or diffrent?
also would a prop off of a 410 fit on a 413. cheers damo
Re: props
Post by ROBBIE » Wed Apr 03, 2013 7:36 pm
Front is longer if that helps
damo
Re: props
Post by damo » Wed Apr 03, 2013 8:01 pm
thought it was but i havnt looked to be honest wi you robbie. do u know if the 410 rear is same as 413?
Re: props
Post by ScottieJ » Wed Apr 03, 2013 9:44 pm
Front props are quite a bit longer than rear props.
410 propshafts are about 1" longer than 413 and samurai propshafts because the diffs are shorter.
So they can be useful on lifted SJs.
Early skinny 410 props have a differnet bolt pattern
later samurais have a different bolt pattern and use larger 10mm bolts
