vitara engine options
Re: vitara engine options
Post by Edweird » Fri Apr 26, 2013 3:16 am
I believe that a Vauxhall engine and Carlton/Manta gearbox is a relatively common conversion for SJs. Not entirely sure how easily it'll drop into a Vitara but I can't imagine it being that hard. Main thing will be wiring and mounts.
Post by ScottieJ » Fri Apr 26, 2013 8:22 am
Vitara's don't have a divorced transfer box like sjs so this makes conversions more awkward, you could swap to an Sj tbox but then you get funky rear prop angles because the Sj has an offset rear diff and the vit has a centred rear diff. It would make life a lot easier to use something that can bolt straight up to the vit gearbox or uses a conversion plate to bolt up.
There is also the 2.5 Suzuki V6 however I'm pretty sure the chassis rails are too narrow on the 1.6 vits for them????
Then again you could go down the Toyota route if you are willing to do all the fab work to fit the hilux transmission in, then you have the options of the supra 2jz 3.0 twin turbo or the 1uz 4.0 v8 :brows:
upjakscreek
Post by upjakscreek » Fri Apr 26, 2013 8:31 am
Sounds like a plan for when I get a little run around. But if a vaux engine and box would mate up that sounds like the easiest and keep just 2wd. Im not sure all the fab work would be worth it with everything else id need to change aswell.
how would I even work out what would mate to the vit box?
Neil
upjakscreek
Post by upjakscreek » Fri Apr 26, 2013 10:10 am
Manta gearbox on eBay for 50 quid aswell :D
Post by ROBBIE » Fri Apr 26, 2013 10:31 am
dan_2k_uk wrote:Heres a good start for fast Vit ideas
Let me have a go when you've finished it!
:D
Driven this, but it was on Gran Turismo
Post by Edweird » Fri Apr 26, 2013 12:08 pm
:D
You done the glitch where it gets up to 1000 miles an hours and then starts breaking the laws of physics?
suzukisteve
Post by suzukisteve » Fri Apr 26, 2013 7:10 pm
dear god its an escudo! what id give to have a go in one of those monsters!! and just think it started life as just a regular old suzuki. someone get me some spanners and some gaffer tape! quick! :hahaha:
pickle power!
Post by ROBBIE » Fri Apr 26, 2013 7:23 pm
:D
No, I feel I've missed out :cry:
Post by Edweird » Fri Apr 26, 2013 11:26 pm
ROBBIE wrote:No, I feel I've missed out :cry:
Oh, you can drive through walls and things with it.
Ladaman
Post by Ladaman » Fri Apr 26, 2013 11:50 pm
A lively little number!! :hahaha:
Some serious "cuts" going on on the corners here.
Click Here for Youtube Video
