what do they need to run
maxlee
Post by maxlee » Thu Apr 25, 2013 8:02 pm
alright guys
looking a turf and the wiring is a right mess, so i'm thinking off ripping it all out and starting again.
so the question is what wires dose the engine need to start and run?
live to the coil, live to the starter pluss trigger wire from a switch wire from the alternator?
not sure on the dizzy do these have points? or electric ign?
mk1joe
Re: what do they need to run
Post by mk1joe » Thu Apr 25, 2013 10:12 pm
what one is it? a 410 will have points, a 413 doesn't. i think the 413 dizzy is just a little sensor that does the same job as points though so its similar to wire up. someone here will know:)
Post by Darrell » Thu Apr 25, 2013 10:45 pm
I scribbled this out before for a 413, its up to you if you want the oil pressure and 4wd light.
The 410 will be a little different as it has a wire bypassing the 410 ballast resistor.
Basic Wiring.jpg (106.7 KiB) Viewed 6776 times
maxlee
Post by maxlee » Sat Apr 27, 2013 10:16 am
thanks guys sorry its a 410
going to get some bits from work and get involved i think :)
going to leave the stock wiring there till its up and running then its all going in the bin :thumbup:
will do a build topic soon
Post by Darrell » Sat Apr 27, 2013 2:03 pm
Modified for a 410 (I hope :oops: . As usual, if anybody sees I've screwed up please say so :thumbup: )
410 minimal wiring.jpg (45.63 KiB) Viewed 6739 times
The alternator wiring may be different if you have a early 410 with the voltage regulator not built in.
maxlee
Post by maxlee » Sat Apr 27, 2013 10:46 pm
thanks mate i thought the alt and starter were connected buy thicker wire to the + terminal?
Post by Darrell » Sat Apr 27, 2013 10:58 pm
They are , that's just the diameter of my pen :D
Post by Darrell » Mon Apr 29, 2013 8:25 pm
any better ;)
410 minimal wiring.jpg (48.15 KiB) Viewed 6693 times
Post by Jordi » Mon Apr 29, 2013 9:12 pm
Darrell wrote:They are , that's just the diameter of my pen :D
:hahaha: :hahaha: That just amused me. I love the fact you even went away and made the lines thicker and colour coded. Must have been a particularly boring part of the day when you found time to do that.
I'm sure you deserve a special tag line Darrell for all your diagrams and drawings you do for us.
maxlee
Post by maxlee » Thu May 02, 2013 7:11 am
:oops: my bad sorry mate
thank you :thumbup:
