side lights flashing when hazards on
- dazerede
I have a problem when I put my side lights on and and put my hazards on my side lights flash a little bit aswell
Can any body help Chears
I will upload a vid in 20 mins
4” calmini lift kit
4” calmini lift kit
Re: side lights flashing when hazards on
Bad earth somewhere.
- turbo-tom
Sounds like a bad earth to me aswell when i put my foot on the brakes sometimes my right indiacator comes on and if i wiggle the earth the fault clears it self
Tom
Ford Fiesta ST
Ford Fiesta ST
- dazerede
Ok Chears guys just had a look and seen my front sidelights and indicators was earthed on the same bolt so I made it connect to different bolts but still not working so I will have a look at my rear bumper
Chears guys as long as I know its a bad earth
4” calmini lift kit
4” calmini lift kit
I'm going with bad earth as well and you have only recently had the bumper in bits
- suzukisteve
- Suzuki Guru
yup, a good scrubbing with some emery cloth and liberal amounts of wd40 on the earthing points should do the trick
pickle power!
- dazerede
I have given up on it gave all the earth connections a sand down and a spray of wd40 but its still not fucking working right
It is only happening on the rear bumper front is all good
I have a heavy duty rear bumper which the lights sit in and where the lights bolt on to the bumper that us where it is earthed
Plus has any body got a diagram of the religh by the fuse box
4” calmini lift kit
4” calmini lift kit
Try any old piece of wire or a jump lead to connect your bumper earth to the body and see if this helps. I've got loads of diagrams if needed
These do
- Untitled - 1k.jpg (159.26 KiB) Viewed 5740 times
- indicator circuit.jpg (51.42 KiB) Viewed 5740 times
- dazerede
Yr might try the wire thing rmoz
Chears
Chears
4” calmini lift kit
4” calmini lift kit
