F10D Viability
Re: F10D Viability
Post by dan_2k_uk » Thu May 02, 2013 3:32 pm
Have you done it yet? :poke:
Re: F10D Viability
Post by Jordi » Thu May 02, 2013 4:55 pm
dan_2k_uk wrote:Have you done it yet? :poke:
No pressure then.
Re: F10D Viability
Post by turbo-tom » Thu May 02, 2013 4:59 pm
Sounds like a good plan to me :guns:
Re: F10D Viability
Post by Edweird » Thu May 02, 2013 6:59 pm
Geez! I've barely had chance to finish thinking about it. I actually went down to a local used car dealer today because I saw he had an Alto 1.1 in. I have a look at it and while the gearbox end looks friendly I'm not so sure about the engine mounts. It's got this weird horseshoe shaped bracket on the end of the engine around the timing belt cover that bolts up to the O/S of the engine bay.
Re: F10D Viability
Post by ScottieJ » Thu May 02, 2013 7:04 pm
You just want to check to see if the block still has the bolt holes for the Sj mounts, ignore the mounts that are used in the alto as the engine is mounted the wrong way ;)
Re: F10D Viability
Post by Edweird » Thu May 02, 2013 7:15 pm
ScottieJ wrote:You just want to check to see if the block still has the bolt holes for the Sj mounts
DARRRRELLLLL!!!!
Re: F10D Viability
Post by ScottieJ » Thu May 02, 2013 7:36 pm
Did you take any pictures?
Re: F10D Viability
Post by Edweird » Thu May 02, 2013 7:54 pm
No, because I'm an idiot and I didn't think of that.
Re: F10D Viability
Post by ScottieJ » Thu May 02, 2013 8:08 pm
No comment :hahaha:
Re: F10D Viability
Post by Darrell » Thu May 02, 2013 8:09 pm
I checked the diagrams for the alto and it came up with this
"Alto MA800 RF410 SB308 SH410 SS80"
I have no idea which one has the f10d engine in it :oops:
I looked for pics of the f10d but this is the only one I found out the engine bay.
