My Sj 410 build
Re: My Sj 410 build
so got back from my girlfriends today been the most of the week so not really much done/started on the sj just took some pictures of engine ,seats and wheels
its turned into more of a boyfriend girlfriend project which is fun
engine bay is muddy and there's a few breathers that need tracing and yes there is a starter motor on the inner wheel arch its fucked got told it was good when i brought the sj but tried it and it doesn't work so might have ago at striping it down and cleaning it out
if someone done it before and has some advice they could give me that would be nice
my lovely muddy vauxhall calibra turbo seats and harnesses its messy as my dads using it as a shed but now the other shed it the garden has been sorted he can move his shit out of my car
the front has 30mm wheel spacers to which came with the sj so that was nice and you can see why i need 16" wheels that will fit
tyre size 205 80 16 kingpin hi-lander diamond tracks
my series 2a that i had when my dad had a bobtail rangerover (thats where i got the wheels from)
my very first sj that i got for my birthday let my moms mate took it off roading she ripped the t-box straight out
Re: My Sj 410 build
I think I have now figured out why the spring hangers have been cut of and re welded on as the rear wheels sit just right in the arches with no spacers so if I'm right that means I could have samurai axels ill takes some pics tomorrow anyway
and also was trying to work out what gearbox someone has used when they put the 1.6 in as its a 5 speed and it has 3 prop shafts if that helps
- dazerede
Re: My Sj 410 build
It properly has a 1.3 gear box
It has 1 prop that comes from gearbox to transfer box and then 1 goes to front axle and other one to rear axle
4” calmini lift kit
4” calmini lift kit
Re: My Sj 410 build
Thanks that sounds about right to what it looks likedazerede wrote:It properly has a 1.3 gear box
- turbo-tom
Re: My Sj 410 build
1.6 engine on the 1.3 box is right as the 1.6 wont bolt up to the 410 box
and as daz above says propshaft from back of gearbox into transfer box then from the transfer box you have the two probs going to the axle oh and sj's are rear wheel drive so there easy to go sideways
Tom
Ford Fiesta ST
Ford Fiesta ST
Re: My Sj 410 build
Sideways funturbo-tom wrote:1.6 engine on the 1.3 box is right as the 1.6 wont bolt up to the 410 box
- turbo-tom
Re: My Sj 410 build
Okay this video will explain it. okay its more of a powerslide but you get the idea , and please not its not me! im sensible...
Click Here for Youtube Video
Tom
Ford Fiesta ST
Ford Fiesta ST
Re: My Sj 410 build
Watching that really make me want to take mine out playingturbo-tom wrote:Okay this video will explain it. okay its more of a powerslide but you get the idea , and please not its not me! im sensible...
Re: My Sj 410 build
Axle pics
Swapped over the spotlight for some other ones I had as the ones on there are too nice to see get smashed and finished painting the wheels and put other stuff back on like my tonka plate and made the rear arch fit abit better
Few inside pics and a lovely pic of my ecu the hard tops coming off tomorrow so I can see how I'm sorting out how I'm going to sort a roof out and back for when I pick up it
Re: My Sj 410 build
Not quite sure what's been going on with the spring mounts, but they look like they could do with a bit of bracing.
Edit, Had a re-read and you said earlier they had been cut off
What a pooh job they made of putting them back on.
Dad I'll sort it
Dad I'll sort it
