petrol in the oil
timwilks13
SCUK Website Padawan
Re: petrol in the oil
Post by timwilks13 » Thu May 23, 2013 8:50 am
All sorted, it was just the head gasket but had blown right between cylinder 3 and 4 which explains why both cylinders weren't firing!
Jordi got my 410 5 speed yesterday and checked that clutch and flywheel i had in the back and you're right it is slightly bigger! So if anyone needs a SJ413 clutch and flywheel let me know!
Post by Jordi » Thu May 23, 2013 9:50 am
Sold. I'll take them.
kiwizook
Post by kiwizook » Thu May 23, 2013 10:39 am
it's good you got that one sorted, at least it's quite easy to fix :D
timwilks13
Post by timwilks13 » Thu May 23, 2013 10:43 am
kiwizook wrote:it's good you got that one sorted, at least it's quite easy to fix :D
The hardest bit was cleaning off the engine block head. When taking the old gasket off it was really stuck down and left little paper chunks behind! Took about an hour to clean it all off so it was flush again! Just glad its working again.
Post by Jordi » Thu May 23, 2013 12:48 pm
Pleased you got it going again bud.
Be sweet as a nut again now.
