Splitting steering box / arm ball joint
Re: Splitting steering box / arm ball joint
I'll give that a try in the morning, i'll be ready to go before machine marts open anyway.
- mike harris
- SCUK is my life
Hammer wasn't doing anything.
I'll have a mess about with it tomorrow. Failing that i'll get a splitter to do it.
I'm pretty sure I took the turret nut thing off, put a regular nut on it, then used a big metal pole from the top through the engine bay. Whacked it with le sledgehammer until it came loose, then took the nut off and removed...
A good squirt of wd40 and using 2 hammers hit on either side of the arm where the bolt goes through. That should be enough to shift it.
- turbo-tom
Mine came about with Ferris's method and thats the method I always use if not I use Wills method and it works second time!
Tom
Ford Fiesta ST
Ford Fiesta ST
I bought a ball joint splitter. Only £10 and did the job no fuss.
