The little bolt bit that stops the gear lever spinning round
Post by Jordi » Tue May 28, 2013 12:19 am
You all know the one. It bolts in from the back of the box.
Where can i get a one? There was a mod on here somwhere to sort it but i can't find it.
Ricky-410
Re: The little bolt bit that stops the gear lever spinning r
Post by Ricky-410 » Tue May 28, 2013 1:01 am
i just got a normal bolt and ran the end in a bench grinder until it fit in the gap, works great. no slop at all
Post by dan_2k_uk » Tue May 28, 2013 6:33 am
I did the same as Ricky but used an angle grinder and a drill.
ianedwards
Post by ianedwards » Tue May 28, 2013 2:15 pm
id recomend using a bolt, and doing as the guys say.
i bought a kit from mountain goat performance, came with a new bolt, and replacment bushes for the gear stick and transfer box,
im going there on way home, do you want me to get the bolt out and get the dimensions for you to copy.
Ian
Ian. :)
Post by Jordi » Tue May 28, 2013 3:03 pm
That would be brill bud.
May even buy that kit and do the lot.
Post by Jordi » Wed May 29, 2013 4:51 am
If they are correct it means i managed to find part numbers all by myself. Gonna give Suzuki a ring later on. Don't think they're open at 04:50.
01935-08006 Bolt
08321-21083 Spring Washer
Post by Jordi » Wed May 29, 2013 11:23 am
My suzuki dealer didn't recognise those part numbers but have ordered me the correct parts off this diagram. About £3 i think he said.
ianedwards
Post by ianedwards » Wed May 29, 2013 3:44 pm
Sorry, I got called back into work on the way home yesterday. I didn't have a chance to go up there but it sounds like you have sorted it out. :thumbup:
Ian
Ian. :)
Post by Jordi » Wed May 29, 2013 3:46 pm
All sorted cheers. Will be at my local Suzuki dealer tomorrow.
