Project KJA
Re: Project KJA
Post by dan_2k_uk » Wed May 29, 2013 3:55 pm
Cant wait. Keep it up dude!
OllieSJ
Re: Project KJA
Post by OllieSJ » Wed May 29, 2013 7:05 pm
This is the lid you were after
babakev
Re: Project KJA
Post by babakev » Wed May 29, 2013 7:30 pm
dan_2k_uk wrote:hi
looks like a bit of work uve got there.
regarding the body mounts. a couple of mine were stuck and a good ammount of wd40, lifting it up and down, jacking it up and down, and twisting the metal parts with a big set of mole grips did the trick.
let me know if you find some body mount rubbers. the only ones i could find with a quick search were from thailand and quite expensive.
Dan :thumbup:
I brought 2" Body mount rubbers on Ebay uk a few months ago for £8. & not got round to fitting them yet !
ianedwards
Re: Project KJA
Post by ianedwards » Fri May 31, 2013 11:32 pm
hi, :snap:
cheers but i managed to save the old ones, it was the metal dome things that had rotted so i made new ones and the tube inserts, rubbers will last a bit longer.
this is the lid thats broken, an inch holding it on lol
lid
lid
lid
lid
front end, welded up and started painting
inside painted, didnt do it all, just the bits that needed it
just painted the bits ive worked on and that you will see, bit more to do on the rear floor
inside of front end painted and all on and bolted up in its last resting place, just got to rub down and paint the out side and putting the new rad in
its coming along
its coming along
new hawse and plate to cover my dads hole he cut
and then comes the new winch rope for the rear winch, i liked the yellow one
in process of cleaning and painting, need to find a badge or something to cover the old indicator holes
Hope you like,
Ian
Ian. :)
OllieSJ
Re: Project KJA
Post by OllieSJ » Fri May 31, 2013 11:40 pm
Good work. If you need the lid you know were i am
Re: Project KJA
Post by donkeychomp » Fri May 31, 2013 11:49 pm
Got these if you can use them...
ianedwards
Re: Project KJA
Post by ianedwards » Fri May 31, 2013 11:55 pm
Cheers, is it the same lid ? if it is ill have it off you.
Like the badges, shame it don't say 413. I'm thinking of putting a black and white Union Jack enamel badge Ive seen there.
Ian
Ian. :)
kiwizook
Re: Project KJA
Post by kiwizook » Sat Jun 01, 2013 12:01 am
very nice work man. this is the standart I had in mind for my 410k a long time ago, has all gone out the window as I thought it was impossible, you might yet change my mind, as I see it is possible, but I'll have to upskill first ;)
OllieSJ
Re: Project KJA
Post by OllieSJ » Sat Jun 01, 2013 12:07 am
ianedwards wrote:Cheers, is it the same lid ? if it is ill have it off you.
Ian
yer only thing i have noticed is that as my dash is slightly faded the colour doesnt match any way its the same 99.9 % sure if not i will pay for postage back some how.
Re: Project KJA
Post by Jordi » Sat Jun 01, 2013 1:26 am
More tidy work Ian. Front end looks spot on.
Looling forward to seeing this on the road.
