Will a 1.3 rocker cover fit a 1.6?
Post by Jordi » Sat Jun 01, 2013 5:17 pm
My 1.6 rocker cover is a bit manky. Will a 1.3 cover fit straight on?
Re: Will a 1.3 rocker cover fit a 1.6?
Post by turbo-tom » Sat Jun 01, 2013 6:16 pm
my guess is you might be able to because you can put the 1.6 head on a 1.3 block etc but i guess that means nothing! try it its only 4 bolts!
Post by Edweird » Sat Jun 01, 2013 6:41 pm
I can't see Suzuki making more than one Rocker cover design for the SOHC 4-cyl G-family engine. Saves on moulds
Post by Jordi » Sat Jun 01, 2013 7:14 pm
They are different shapes.
I don't wanna peel the 1.6 cover off before i know as i haven't got a spare rocker cover gasket.
If i know it'll fit i'll get a gasket and then swap them. If it won't fit i'll just wire brush it down and try the VHT paint again as i like to waste money.
Post by ScottieJ » Sat Jun 01, 2013 9:05 pm
Yes it should fit :thumbup:
Post by Jordi » Sat Jun 01, 2013 9:27 pm
Cheers Scottie. I'll get a rocker gasket and give it a go.
Post by mike harris » Sun Jun 02, 2013 2:00 pm
yeh will be fine !! :)
rtv it !!
