samurai handbrake cable???...help!!!!
Hi all, last week I took my samurai out playing at sibbertoft and managed to break the o/s handbrake cable.After a week of ringing round literally everywhere trying to souce a new one I have failed miserably because as you all probably already know along with many other parts for sj's,they've been discontinued.
My question is, is there a similar cable for another vehicle that can be used instead?...ive already tried a swb vitara cable which has too much slack.
Any help would be great before I blow any more money on this problem.
Thanks in advance!
Thanks in advance!
Re: samurai handbrake cable???...help!!!!
Which cable is it?
I have a complete cable off my samurai for sale.
Its the drivers side one but to be honest, both cables look near enough the same!...how much do you want for it, where are based?
Don't think its the same cable. I have the long cable from handbrake to one drum, then a short cable that joins in the middle of the axle to the other drum.
- Ladaman
- Suzuki Guru
I think I might have the one you are looking for.
Non of the local motor factors could get me the right thing when on of mine snapped, so I bodged one up. It lasted just long enough for the MOT.
I've fitted a transfer brake now, so shouldn't need it. I will see if I have a pic for you. Unless you have one?
- Ladaman
- Suzuki Guru
I think the one I have spare is number 23 on the second diagram.
These are the ends. The top one is my home made one which didn't last long.
- Drum end
- IMG00534-20110307-2143.jpg (579.63 KiB) Viewed 5880 times
- Adjuster end
- IMG00537-20110307-2144.jpg (501.7 KiB) Viewed 5880 times
No I still havnt got one.the one thats broke on mine is number 8 on the 3rd diagram.
But I think I may be able to make those cables fit to the bracket attached to the handbrake lever.
I will have a look after work tomorrow and get back to you.
Thanks for the responses, those diagrams are really helpful.
- Tramp
My samurai is number 3 diagram, when my cable snapped. I went to my local motorfactors, I could not get a drivers side cable, but the passenger side cable was available, I bought x2 passenger side (to replace both the cables) I had to swap the fitting (number 14) over to make it drivers side, it was the only difference between drivers & passenger. jobs a fish
