I may need a new diff...
- suzukisteve
- Suzuki Guru
now im no expert but in my experience when something starts banging about its never good.
so I found a lot of play in my rear diff, not only that but the extra play in the rear prop has rattled the u.j's half to death. took off the rear prop and found the nut that goes on the flange, where the rear prop bolts to the diff ( sorry not overly educated is suzuki drivetrain), was only finger tight!
ive tightened it up for now but I very much doubt it'll be to the correct torque setting, as I didn't have the info at the time.
the noise has stopped and the slack in the diff has lessened although I will still need to replace a couple of u.j's sooner rather than later.
what is gonna be my best option regarding the diff? wait and see how it pans out or whack another in there
I'll be replacing the oil soon as its getting on the murky side.
cheers
steve
cheers
steve
pickle power!
Re: I may need a new diff...
It's new pinion bearings, an oil seal and crush collar time matey will mean you'll need to strip down the diff and reset all bearing preloads and backlash etc.
Ill have a look, might have a good spare 410 diff.
- suzukisteve
- Suzuki Guru
yeah figured that I'll prob have to replace something. I don't really know much about diffs at all if im honest. never worked on em before. are there any write ups on how to replace them and get em setup correctly?
pickle power!
Best of luck
http://forum.suzukiclubuk.co.uk/vi ... =12&t=3349
Steve come and help me do mine so you can learn
- suzukisteve
- Suzuki Guru
Im doing it next weekendsuzukisteve wrote:haha when are you doin yours rob?
- suzukisteve
- Suzuki Guru
Should be saturday afternoon bud and you would be more than welcome to come over
- suzukisteve
- Suzuki Guru
I'll see what I can do dude. are all the ujs on my 410 the same or would they be different depending on where they are? like would the one say next to the transfer box be different to the one by the rear diff? gonna grab a couple today to get them done and out the way
pickle power!
