Power steering, Year 2000 Grand Vitara 1600cc
Re: Power steering, Year 2000 Grand Vitara 1600cc
Post by ScottieJ » Thu Jun 20, 2013 10:03 pm
If the gv2000 uses the same pipes then I have one I could pull off tomorrow night for you. :thumbup:
Post by Jordi » Thu Jun 20, 2013 10:06 pm
If you need to drive it remove the PAS belt.
Remove the old pipe if you can and stick a photo of it up for Scottie to compare. If his isn't a match have a ride round the hydraulic / plant / machinery repair places with it for a quote.
If you just want it fixed asap Pirtek can do it no problem. I would imagine they would be cheaper than Suzuki quoted too.
apwbee
Post by apwbee » Thu Jun 20, 2013 10:09 pm
the fastening of the pipe to the hose seems fairly straightforward, the other side seems more complicated, any heads up?
apwbee
Post by apwbee » Thu Jun 20, 2013 10:11 pm
scottie, how much would you be looking for???
Post by Jordi » Thu Jun 20, 2013 10:12 pm
The high pressure pipe is just bolted to the pump and box with one banjo bolt at each end.
Remove the bolts and if possible cover the holes / refit the bolts to prevent any crud going in. Be careful not to lose the washers.
Post by ScottieJ » Thu Jun 20, 2013 10:18 pm
apwbee wrote:scottie, how much would you be looking for???
Let us check that they are the same first ;) ill take them off and take some pics for you tomorrow evening. I'm not 100% sure the 2.0l pipes will be the same, all depends if the pump mounts in a simulate location.
Post by Darrell » Thu Jun 20, 2013 11:40 pm
I believe the 2000 pipes are different to the 1600 :thumbdown:
I think the corroded pipe is the green one.
Pirtek list banjo bolts in there catalogue and would probably make you a hose with one on either end to replace the green and blue hoses (unless they have a fitting to connect to the blue hose, therefore making just a replacement green hose).
It is on the high pressure side so you can't really bodge something up temporary.
Post by Jordi » Sat Jun 22, 2013 9:23 pm
Get sorted with something?
apwbee
Post by apwbee » Mon Jun 24, 2013 7:18 pm
Currently just cut the belt and working on my Biceps!!! going to get it sorted next weekend, payday on friday!!!
