Sj internal loom
- ianedwards
- SCUK Addict
Sj internal loom
Hi, after some help,
Can any one remember or know how the internal loom is routed in a sj 413, or have a picture handy of the loom in place.
I can't remember for the life of me how it went.
Ian
Ian
Ian.
Ian.
- ianedwards
- SCUK Addict
Re: Sj internal loom
Ok, so after cleaning the 20 odd years worth of crap out the pipes in the dash I noticed cable clips all the way along the inside of the dash, are these for the loom?
Or does it just go on the cross member, or is it a bit of both ?
Any help would be great
Ian
Ian
Ian.
Ian.
Think most of mine is in the clips that run along the tubular bar the dash screws to.
- ianedwards
- SCUK Addict
Hmmmm, will have to see then. Nearly ready for the dash to go in, bit more to clean first tho. Might run it rough, put the dash it in connect it up, and see which clips it will reach and if not cable ties lol
Ian
Ian
Ian.
Ian.
Will probably vary between Spanish and Jap too as the fuseboxes are in different places.
Run them where ever is easiest and out of the way. If no clips are available cables ties and electrical tape
- Dash wiring.JPG (225.16 KiB) Viewed 4878 times
- ianedwards
- SCUK Addict
Hi, cheers chaps, I just seen that in the bible, must have missed it the other day. Looking at the clips on the actual dash it must here been in them, the inside of the clips arnt dusty as every thing else inside the dash is covered dust. That carnt be a coincidence lol plus the clips are in line with that diagram, might be mystery solved. I'm going to do it on the weekend now so ill update when it's in.
Cheers for your help
Ian
Ian
Ian.
Ian.
