rockwatt manifold and su hif44 carb pipe work help needed
Re: rockwatt manifold and su hif44 carb pipe work help neede
Post by dan_2k_uk » Mon Jun 24, 2013 10:04 pm
Think there was one that went to the old carb which gets blanked?
Post by Jordi » Mon Jun 24, 2013 10:22 pm
dan_2k_uk wrote:Think there was one that went to the old carb which gets blanked?
Is it blanked Dan? I think i just effectively joined the old carb feed and return together to complete the "circuit".
Richie
Post by Richie » Tue Jun 25, 2013 5:33 pm
Do u mean the return being the hose that goes to the bottom of the thermostat housing?
Richie
Post by Richie » Wed Jun 26, 2013 9:02 am
These are the water pipes im not sure about
Richie
Post by Richie » Wed Jun 26, 2013 9:10 am
These
Richie
Post by Richie » Wed Jun 26, 2013 9:14 am
This is how I understand it
The far right goes to the bottom of the inlet manifold under the thermostat
The fat one is the bottom rad hose
The left one at the bottom goes to the heater valve closest to the brake res pot
The left top one is the one in the previous pic which doesnt go to anything?
Post by dan_2k_uk » Wed Jun 26, 2013 10:21 am
I will look at mine later if you are still stuck. I cant remember and I am using the 1.3 water rail not the 1.6 one which might have an extra hose position.
Where is the other hose from the heater matrix going?
Richie
Post by Richie » Wed Aug 14, 2013 6:48 pm
Im still stuck on this, the bottom left one im not sure where it goes, any help welcome. If I can get it sorted I still might make wagtail :)
Post by dan_2k_uk » Wed Aug 14, 2013 8:09 pm
The top left in that photo is just blanked with a bolt and a jubilee clip on mine.
Post by dan_2k_uk » Wed Aug 14, 2013 8:31 pm
The hose from the Heater valve goes to the manifold.
The rest are marked here
