cherry bombs exhausts
dazerede
Re: cherry bombs exhausts
Post by dazerede » Thu Jun 27, 2013 12:32 pm
I'm just wondering as I want a cherry bomb to put on my 410 can I keep the front silencer and remove the rear silencer and then add the cherry bomb Chears
4” calmini lift kit :)
Post by Jordi » Thu Jun 27, 2013 12:44 pm
Yup!
Just a case of find the right size cherry to fit the cap or get some exhaust pipe to fill any gaps.
Post by turbo-tom » Thu Jun 27, 2013 12:56 pm
Yep that will work i have the standard first box (want to get rid of it!), then it pipe all the way up to my backbox which is similar to a cherry bomb but it roars more rather then bangs like cherry bombs.
Post by dan_2k_uk » Thu Jun 27, 2013 1:30 pm
Just cut the flange off the back end of the front section and make up some exhaust to take it to a cherry squeezed in next to the fuel tank.
Post by ROBBIE » Thu Jun 27, 2013 1:38 pm
As said just match to your pipe
dazerede
Re: cherry bombs exhaustsk
Post by dazerede » Thu Jun 27, 2013 6:51 pm
Chears guys I don't.want it to be too load
I took the back bit off of my exhaust as the exhaust is in 2 sections fired it up and wow it was load so I might try just putting the cherry bomb on it to see how good it is if its crap I will only have 1 silencer and a cherry bomb on it
Post by turbo-tom » Thu Jun 27, 2013 7:27 pm
Mine sounds like a tank with just the manifold! sounds allright just way over the top :hahaha:
dazerede
Post by dazerede » Thu Jun 27, 2013 7:32 pm
I'm not sure to keep the rear silencer on or remove it
It would be quicker to keep it on
Does a cheery bomb act as a silencer a bit or not
As it was too load with just the front silencer on it
Confused
Post by turbo-tom » Thu Jun 27, 2013 7:36 pm
Keep all the exhaust system. But chop the rear box off and replace it for a cherry bomb. That way it will be quietish on tickover but when you put the pedal to the metal it will go deeper and probably pop n bang a bit
dazerede
Post by dazerede » Thu Jun 27, 2013 7:54 pm
This is wat my exhaust looks like
If I remove the rear box it will take longer to make
