Front gearbox oil seal emergency!!!
Post by Jordi » Sun Jun 30, 2013 4:14 pm
How much? Where from? How to do it!!!!
Help urgently required!!!!!
Presuming thats what it is as the oil is coming out the bottom of the bell housing
Ladaman
Re: Front gearbox oil seal emergency!!!
Post by Ladaman » Sun Jun 30, 2013 4:26 pm
Or is it engine oil and the crank seal has gone?
Post by Jordi » Sun Jun 30, 2013 5:28 pm
Gearbox oil. Smell and taste checked.
Post by twiss » Sun Jun 30, 2013 6:04 pm
Jordi wrote:Gearbox oil. Smell and taste checked.
Yum yum!!! :P
Post by Jordi » Sun Jun 30, 2013 6:12 pm
Just gotta see how it develops. Not sure if it is gonna be an issue. Just dribbled a bit while i was doing the brakes then stopped. Its been out again and hasn't leaked anymore.
suzukisteve
Post by suzukisteve » Sun Jun 30, 2013 6:19 pm
worse case you can always put a stop leak treatment in as a temp fix until after you get back mate
pickle power!
Post by Jordi » Sun Jun 30, 2013 6:22 pm
Stop leak in the gearbox?
Post by dan_2k_uk » Sun Jun 30, 2013 6:30 pm
Jordi wrote:Stop leak in the gearbox?
Just thickens the oil to slow it down.
I guess you can just take that from cover off to replace the oil seal but then you will need a gasket for that too.
Post by Darrell » Sun Jun 30, 2013 6:54 pm
According to the tinternet.......................A 413 / samurai has...............
Post by Jordi » Sun Jun 30, 2013 7:12 pm
I am right in thinking its just take the cover off behind the release bearing. Swap seal & refit?
