primer questions
- suzukisteve
- Suzuki Guru
primer questions
afternoon everyone, was just wondering whats best type of primer to use for bare metal? something that will help hold rust back mainly as it'll be used on the arches
pickle power!
Re: primer questions
red oxide primer or zink primer maby. they come in the form of a spray paint and they react with the metal to stop it rusting. If its the inside of the arches than you can overpaint it with body underseal and it will never rust.
- suzukisteve
- Suzuki Guru
sweet, I was lookin at some zink primer at work the other day. It'll have plenty of waxoil based underseal an all
cheers bud
cheers bud
pickle power!
Yeah zinc primer. Get a high enough zinc content and you can weld through it too.
- turbo-tom
I use red oxide and would touch anything else! for general painting but if im spraying i would use just a general grey or white primer depending on what colour im spraying.
Tom
Ford Fiesta ST
Ford Fiesta ST
I loved the red oxide I used on mine but the top coat wouldn't take that well to it.
Find something compatable with the green paint Scottie gave you with the truck.
zinc primer over etch primer, it's not cheap that way, but lasts a long time
