Diff oil seal
Diff oil seal
I noticed the flange on my rear diff was damp and everything else was covered in dry crusty mud.
Taking a wild guess its another oil seal to do. Is it a simple job?
Any chance of a diagram and part number please Darrell
Re: Diff oil seal
Av got the part num somewhere gotta get this done on myn local suzi dealer charged me 6quid for seal
1994 sj 413 sierra
cheker plate door cards
cd players
asin free wheeling hubs
99% rust free
alloys
bukets
some leaks here and there
cd players
99% rust free
alloys
bukets
Re: Diff oil seal
Is there any play in the bearing?
Ideally you should replace the crush collar as well and reset the pinion bearing preload, otherwise the pinion bearings will fail prematurely.
Might be a good time to fit a solid crush collar
Re: Diff oil seal
Think you will need a new crush collar or to re-setup the diff if you undo and re-rorque the pinion nut.
I had written it anyway!
Re: Diff oil seal
Not quite so simple then. May just keep topping it up till i get full float and rebuilt diff in my spare axle.
Re: Diff oil seal
I would fix it before it's too late! That's what I was doing until 90% of the oil disappeared over a short period of time and then the carrier bearings got starved of oilJordi wrote:Not quite so simple then. May just keep topping it up till i get full float and rebuilt diff in my spare axle.
- turbo-tom
Re: Diff oil seal
When I pulled my sj out the garage for the firstbtime in two gears my front pinion seal went and it dumped all its oil along the a27 and murded the diff.
Tom
Ford Fiesta ST
Ford Fiesta ST
Re: Diff oil seal
So maybe a diff rebuild is now going to be a priority.
Re: Diff oil seal
I'm sure it'll be fine for the weekend but i would do it sooner rather than later, its only a crush collar and seal. you don't need to fully strip the diff to change them.
Re: Diff oil seal
I had a read through the diff service stickie before.
Quite indepth stuff. Sure i can manage. I'll get the bits ordered for next weekend. Keep checking the level. Pleased i decided to trailer it down.
Luckily it doesn't do many miles and its not a problems checking the oil at home or at work.
