On road Gear Ratios
Re: On road Gear Ratios
Post by dan_2k_uk » Thu Jul 04, 2013 4:30 pm
Or just fit complete 413 axles with 413 diffs to save money and time.
Re: Gear Ratios
Post by ScottieJ » Thu Jul 04, 2013 4:31 pm
twiss wrote:
ScottieJ wrote:The G13 and G16 doesn't like to rev as much as the F10.
I beg to differ!
They can but they need 8 additional valves in them ;)
For 8v engines though you're definitely right on that one
In strength terms not power, You can thrash an f10a to death and rev the tits out of it all day as long as its healthy. The G series (not including swift gti) bottom ends can't handle the same sort abuse and will eventually throw a rod or kill the bottom end. How many F series engines have you known to throw a rod? I've not heard of one but I know a fair few people who have done it with a G-series engine, Trotter for one :lol: Karis's engine was the first F series I've had a bottom end failure (at 70mph) and it was still holding some oil pressure and didn't throw a rod :hahaha:
And Jay providing you get the sammy diffs with the early smaller flange PCD they bolt straight up.
Jay18
Post by Jay18 » Thu Jul 04, 2013 4:36 pm
so sj413 axles will bolt straight to my 410 springs with changing axle perches or anything like that?
would my 410 brakes all fit to the 413 axles? and would my 410 prop shafts bolt straight up to the diffs?
would i have to modify my steering to fit the 413 axles?
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
Post by twiss » Thu Jul 04, 2013 4:38 pm
Jay - Yes 413 axles will go straight onto your springs, I would go for the 413 brakes as they are bigger and better. 410 prop shafts will bolt on okay, as scott says if they have the early small holes on teh flanges
Not sure about the steering...
Scott - My mate bust a rod on his 410! Grenaded the engine pretty much, mind you this is the same person that managed to slip his cambelt 4 or 5 teeth round while racing a Skyline in a 413.. could explain it!
Post by dan_2k_uk » Thu Jul 04, 2013 4:39 pm
413 will all bolt up no problem. The only thing I dont know about is the flange size on the diff.
Post by twiss » Thu Jul 04, 2013 4:44 pm
Just remember if the holes are different you can do a cheeky drill job ;)
Post by turbo-tom » Thu Jul 04, 2013 4:46 pm
But if you dont drill it square and true you can cock it right up and get mental vibrations :shock:
Post by ScottieJ » Thu Jul 04, 2013 5:07 pm
Any engine will blow up if you try hard enough, just saying the F series are stronger ;)
I answered the prop flange question in my last reply ;) It's only the late samurai diff flanges that are different, make sure you get ones with 8mm bolt holes. :thumbup:
413 and 410 front brakes are identical ;) they've only used 2 different calipers on SJs, Aisin or Girling, the small variations in shoe size between SJs won't make any difference either.
And as for the ratio questions, this should answer it all so you can work out what set up to run.
413 and samurai gearboxes have a different 5th gear ratio so I have added an extra column to each set up to show the difference, 1st-4th share the same ratios. might need to click on it to see the full size image.
ratio comparrisons.jpg (246.66 KiB) Viewed 4197 times
Jay18
Post by Jay18 » Thu Jul 04, 2013 5:14 pm
cheers scottie, will have a sit and think about this
just wondering if its worth spending all this money on the sj or using the money to buy a vitara :/ hmmm..
the question is...
vitara, lwb vitara, grand vitara or jimny...
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
Post by ScottieJ » Thu Jul 04, 2013 5:17 pm
Sjs are cooler!
