suzuki steve's 410 build
Re: suzuki steve's 410 build
Post by Jordi » Tue Jul 09, 2013 10:48 pm
Tiiiiiiiddddddddyyyyyyyyy!!!!!!!!!
That is looking awesome Steve!
suzukisteve
Post by suzukisteve » Tue Jul 09, 2013 10:52 pm
sorry I forgot to mention one thing.
there is a plate that covers the fuel filler pipe. its always bugged me as I could never get behind it properly to clean mud outta there etc etc. so I got shot of it and replaced it with something a bit more practical.
my mate paul being a cracking fabricator build this little gem for me. I cant find the pic of it now its been fully seam welded and painted etc but you get the idea.
this way I can remove it and clean behind it to stop the rust around the filler neck.
what do you guys think?
pickle power!
suzukisteve
Post by suzukisteve » Tue Jul 09, 2013 10:55 pm
cheers jordi, its mainly down to paul as he's been welding for years now ive been seam sealing, cutting cleaning metal, painting etc etc so I cant take full credit. but im super stoked about it!
cant wait till the grand road and off road test!!!!!
pickle power!
Post by ScottieJ » Tue Jul 09, 2013 11:10 pm
Looking good dude :rockin:
And yes the roll hoop just bolts to the rear arches and to the top seat belt mount, that's just how the factory roll hoops fit. As said it might need some mods for a standard soft top SJ though as it used to be in my Sj and that was once a tin top.
suzukisteve
Post by suzukisteve » Tue Jul 09, 2013 11:19 pm
thats cool mate. bolting to the arches sounds, well, sketchy in a roll situation. so I may leave it until I can figure a way to attach it to the chassis or whatever so its solid as hell.
either way tho ITS NEARLY ON THE ROAD!! :rockin:
pickle power!
Post by dan_2k_uk » Tue Jul 09, 2013 11:23 pm
I have a similar roll hoop. I am going to weld thick spreader plates into the arches to spread the load. With the VL the arches are considerably stronger anyway.
Good work. Keep up this pace and it will be done in no time :thumbup:
suzukisteve
Post by suzukisteve » Wed Jul 10, 2013 10:17 pm
right lads, last arch done and dusted. just a small bit left to do in the back.
decided to experiment with a rocker cover. gonna see how the paint used on the bodywork holds up. I havent got high hopes as its not a high temp paint, but sometimes you just gotta try these things I guess.
only a couple pics tonight im afraid
cleaned up ans started masking
primed up. the letters will have a polished effect and the primed areas will be green. thats if it works of corse
final arch in progress. now finished
pickle power!
Post by turbo-tom » Wed Jul 10, 2013 10:39 pm
Looks funky mate! :D
Post by donkeychomp » Wed Jul 10, 2013 10:50 pm
You should have no probs painting the rocker box cover with normal paint, I've done all of mine with a rattle tin and some lacquer and they lasted for years!
suzukisteve
Post by suzukisteve » Wed Jul 10, 2013 10:53 pm
should look the nuts if all goes well. Cheers go forr inadvertently reminding to buy some lacquer tomorrow :thumbup:
pickle power!
