Fuselink info
Fuselink info
Post by Darrell » Sat Dec 22, 2012 10:06 pm
Another diagram.
Fuselink 2.jpg (72.38 KiB) Viewed 56133 times
Fuse link wire.jpg (79.27 KiB) Viewed 56133 times
Suzuki SJ samurai fuselinks.jpg (135.81 KiB) Viewed 56130 times
Re: Fuselink info
Post by Darrell » Sat Dec 22, 2012 10:20 pm
I know a few of you have replaced these with larger wire and fuse holder/fuse.
I've seen 30 or 40 amp used.
Feel free to add any info on what you have done :thumbup: .
Re: Fuselink info
Post by Darrell » Sat Dec 22, 2012 10:32 pm
According to the tinternet the green is 0.5mm and rated at 13amp continuous and 40 amp blow.
Seems low to me if you had the heater fan - lights - wipers etc on must be near the limit ?
I would think a fuselink is much slower blowing than a standard blade fuse so could take a little overloading for some time before it melted. However a dead short would melt it in seconds :thumbup:
I dunno :er:
Here's some normal blade fuse info anyway.
Re: Fuselink info
Post by ScottieJ » Sat Dec 22, 2012 10:42 pm
Good info Darrell! Promoted to sticky status :thumbup:
Re: Fuselink info
Post by dan_2k_uk » Sat Dec 22, 2012 11:24 pm
I had a 35A blade fuse in mine and blew it a few times. 40A seems to be the magic value.
Re: Fuselink info
Post by Edweird » Sun Dec 23, 2012 1:00 pm
Darrell wrote:According to the tinternet the green is 0.5mm and rated at 13amp continuous and 40 amp blow.
I've got a 30 Amp blade fuse in mine and I ran it for about 5 minutes the first time I put it in with the engine, wipers, all lights, internal fan, fag lighter etc. and it didn't blow. I've driven home at night in the rain a few times now with music and the heater on and it's still fine. It's been in for at least 2 or 3 months.
Re: Fuselink info
Post by Darrell » Sun Dec 23, 2012 4:23 pm
Thanks for the input guys. I see most standard blade fuses only go to 30amp but a few people sell 35 and 40 amp ones. I also see most blade fuse holders are only rated at 30 amps but again if you shop around you can find 40amp ones. Alternatively a "Maxi " blade fuse and holder could be used.
Rhinoman
Re: Fuselink info
Post by Rhinoman » Fri Aug 30, 2013 10:34 am
ianedwards
Re: Fuselink info
Post by ianedwards » Sun Sep 01, 2013 10:30 am
Doh, the link on mine was all joined with blocks so ive soldered a nice new wire in not realising what it was actulay for. oops. shall get a 40 amp fuse to go in line lol.
Stupid git lol
Ian. :)
windsor
Re: Fuselink info
Post by windsor » Sun Sep 01, 2013 4:10 pm
40amp fuse with 50amp rated holder(a few quid of amazon ) on mine have a/c and power strering kept bolwing 35s
1994 sj 413 sierra
cheker plate door cards
cd players
asin free wheeling hubs
99% rust free
alloys
bukets
some leaks here and there
