Wider Tyres sticking out of arches, legal?
- Sj410red
Hi all, just fitted 32mm spacers to my sj410, it has the smaller plastic arches fitted but the tyres protrude upto 1" looking from above, is this legal? I have trawled many forums and seems to be a grey area that it would pass an mot ok but plod may think different. Any answer please, thanks Richard.
3" calmini lift springs
6" shackles
Rough Country Shocks
Z bar
32mm spacers
Aisan free wheeling hubs
Roll bar
Snorkel
K&N air filter
Poly bushes all round
Front Diff guard
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
Re: Wider Tyres sticking out of arches, legal?
If you get a copper on a bad day (or a jobs worth) he will pull you for it. It's a non-endorsable (no points but fixed penalty fine) offence. Code 380 under construction and use regs. "No wing/mudguard fitted"
But he's you are correct it will pass an MOT as it is not covered in the MOT.
As far as I'm aware you can have the sidewall bulging out but all tread surface that makes contact with the road must be covered, I've never had any issues with a few mm of tread sticking out slightly.
- suzukisteve
- Suzuki Guru
extended arches to be safe in my opinion
pickle power!
- turbo-tom
my disco and suzuki the wheels stick out a little with the extended arches mr plod aint pulled us yet!
Tom
Ford Fiesta ST
Ford Fiesta ST
turbo-tom wrote:suzuki the wheels stick out a little with the extended arches mr plod aint pulled us yet!
Might help if it was actually driven on road
- suzukisteve
- Suzuki Guru
ScottieJ wrote:turbo-tom wrote:suzuki the wheels stick out a little with the extended arches mr plod aint pulled us yet!
pickle power!
- Edweird
And they can't dear to look at the Land Rover long enough to notice.suzukisteve wrote:ScottieJ wrote:turbo-tom wrote:suzuki the wheels stick out a little with the extended arches mr plod aint pulled us yet!
If you like the look leave it pal. If you like extended arches get some on and you will be all legal
I run 235/75x15 on 7" alloys that stick out about 1" with the offset. They look cool and I have never had any bother from the cops
Mine stick out about a inch and never had any hasstle from it will have to go wide arches with new tyers tho 4inch sticking out wont go down well
1994 sj 413 sierra
cheker plate door cards
cd players
asin free wheeling hubs
99% rust free
alloys
bukets
some leaks here and there
cd players
99% rust free
alloys
bukets
- dazerede
This is what mine looks like 410 axles 32mm solid spacers and 235/75/15 tyres
- IMAG0009.jpg (1014.26 KiB) Viewed 6957 times
4” calmini lift kit
4” calmini lift kit
