body coulour?
body coulour?
Hi All, i'm a newbie and hope you don't mind me signing up to asked a long winded question. I bought a 2001 Grand Vitara from a dealer. I paid probably over the odds at £2325 with 92000 on the clock but it was nice condition compared to others I looked at and had the 3 month dealers warranty. The gears are very notchy and the wife can't get them in at all so it's going back for checking out on Friday. Now my question, the car is black the dealer said it has bluey/black on the logbook but I have not received the new one yet to clarify. We did a check on the vehicle and it has not been resprayed, no crashes but it is blue on the check details. When looking under the bonnet everything is like a army greyish green colour. Is this usual with the Vitara to be a different colour to the main body?
Any help appreciated.
thanks
thanks
- mike harris
- SCUK is my life
Re: body coulour?
Av never looked under a vit but when i used to work at a mot station i did notice a lot of newwer cars where left in grey primer under the bonnet and that
1994 sj 413 sierra
cheker plate door cards
cd players
asin free wheeling hubs
99% rust free
alloys
bukets
some leaks here and there
cd players
99% rust free
alloys
bukets
Re: body coulour?
Well I guess you have a Z5J one
- vitara colours 2001.png (39.8 KiB) Viewed 7006 times
Re: body coulour?
Code position
- colour code.jpg (184.5 KiB) Viewed 6994 times
Re: body coulour?
Thanks for your help chaps, Derrell that looks like the color I have, I will check the code on the car later and let you know.
Re: body coulour?
I'll check under the bonnet of our GV can't remember if its a different colour.
As for the notchy gears, check the clutch pedal where the pin goes through connecting it to the clutch master cylinder. If its anything like ours it's ovaled out so there is quite a bit of play before the clutxh starts to disengage and doesn't quite fully disengage. Also might be worth getting them to bleed the clutch system to make sure there's no air in it.
Reminds me I must get around to pulling the pedal out, welding the hole up and re-drilling it this weekend
Re: body coulour?
Thanks Scottie, that does make sense. I am taking it back in the morning and they are going to see if there are any adjustments they can make. I assumed it would be bleeding the clutch but I bet they don't think to try the pedal pin.
Re: body coulour?
Scottie, they checked the pedal today and the hole was elongated. The gears are slightly better going in now but still knotchy not smooth. Perhaps this is how 2001 vitaras are?
