just got my self a 1.6 8v engine 4 my sj ( help )
carlsush
Post by carlsush » Sat Sep 14, 2013 4:20 pm
wot engine mounts do i ues as my 1.3 1ns r gone
wot carb 2 use the 1 with the 1.6 or do i use the webber off my 1.3
and help with the drivers side mount
:D
Re: just got my self a 1.6 8v engine 4 my sj ( help )
Post by ROBBIE » Sat Sep 14, 2013 4:44 pm
Engine mounts are the same on both. If original carb is ok that can be used or I do believe you can use the webber. Driver side needs to move forward
carlsush
Post by carlsush » Sat Sep 14, 2013 10:08 pm
the vitara mounts r bigger and do u no how much i need 2 move the mount
Post by ROBBIE » Sat Sep 14, 2013 10:14 pm
If remember right I'm using vit mounts now in mine and sorry it was a few years back that mine was done. What we done was bolt the mount to the engine and the metal plate, sat the whole thing in where it looked right then tacked the bracket in. Then took the engine and box out and welded the bracket in place.
Post by turbo-tom » Sat Sep 14, 2013 10:19 pm
in my own opinion the 1.3 are still up to the job but its personal choice! :thumbup:
Post by twiss » Sun Sep 15, 2013 1:25 pm
I always use the 1.3 engine mounts, on the drivers side you need to drill a new hole about 2cm back and about 1cm down
I usually lower the engine in on one mount to give me a better idea of where the hole needs to be
You may need to space it out a bit otherwise the whole engine and gearbox will be tilted to one side.
if you use the weber you will probably have to change the jet for the bigger engine to get the best performance...
carlsush
Post by carlsush » Sun Sep 15, 2013 6:19 pm
So do i not use the black braket the mount bolts 2 i just bolt it down
Post by ROBBIE » Sun Sep 15, 2013 6:25 pm
I used the black bracket but I think mine might be a bit to high for some peoples likings but it is level so I'm happy
Post by dan_2k_uk » Sun Sep 15, 2013 6:29 pm
Use the spreader plate on the passenger side but on the drivers side just drill a single hole for the rubber mounts stud to go through.
Henry
Post by Henry » Sun Sep 15, 2013 6:37 pm
I used RRC engine mounts with holes re drilled. Also on the T box too
