Transfer box mounts
Re: Transfer box mounts
Post by turbo-tom » Sun Sep 15, 2013 12:03 pm
in the message box were you type to reply etc there is a ebay button push that and then put your code in ie
Code: Select all
[ebay]111163606411[/ebay]
so it looks something like that (ignore the code box)
and then you get something like this bud
Click Here for Ebay Listing
:thumbup:
Sj410red
Post by Sj410red » Sun Sep 15, 2013 1:50 pm
Ok cheers for that Tom... Scottie, if I got longer bolts I cud add and extra poly bush top and bottom like that set you linked to me. My stock 1s are shot really, had quite a vibration thru the t box stick. I have noticed ther is more of a transmission noise now with what I have done but no vibration.
3" calmini lift springs
6" shackles
Rough Country Shocks
Z bar
32mm spacers
Aisan free wheeling hubs
Roll bar
Snorkel
K&N air filter
Poly bushes all round
Front Diff guard
Sj410red
Post by Sj410red » Sun Sep 15, 2013 3:48 pm
I've just had a re-mod on the mounts I've added a 1/2 inch poly bush top n bottom, what do u think?
Before
Before
And after, going for test drive now to see if its reduced t box noise in cab
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
Post by turbo-tom » Sun Sep 15, 2013 8:04 pm
cant see any problems with that mate! sj's a known to have loud transmissions
Rambo416
Post by Rambo416 » Sun Sep 15, 2013 8:24 pm
Hello there am new to this site
i had same problem with shaky 4wd stick and changed to the mounts ScottieJ has mentioned but now the back end shakes and vibrates a lot around 40mph
WHAT HAVE I DONE WRONG?
any help guys would be great cheers
Sj410red
Post by Sj410red » Sun Sep 15, 2013 8:44 pm
Hi, have you checked yur uj's on rear propshaft? Perhaps there worn and giving the vibration, mine failed its mot on bad joints, fitted newer 1 and it was a lot quieter than before.
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
Post by Jordi » Sun Sep 15, 2013 8:53 pm
I'm running those ones in Scotties link. No problems as yet.
Mine came from Dave @ Llama though.
http://www.llama4x4.com/page5.htm
Rambo416
Post by Rambo416 » Sun Sep 15, 2013 9:29 pm
I have changed the prop as i had the splines badly worn and uj's and splines are now good
however when i fitted new mounts i put the rubbers in the middle of the mounts
I.e how should they be fitted cos they maybe wrong
cheers
Post by Jordi » Sun Sep 15, 2013 9:40 pm
Rambo416 wrote:I have changed the prop as i had the splines badly worn and uj's and splines are now good
cheers
Any photos of them?
I runs the Llama mounts and all is good. I did have to cut a bolt down a bit though. One of the bolts would only go in from the bottom up overs and when tightened it touched the bottom on the body making a hell of a noise. Chopped a few mill off and its spot on.
I would go through and check all bolts for tightness in the drive train.
Rambo416
Post by Rambo416 » Sun Sep 15, 2013 10:08 pm
ok they are done on all three like this?
