I get yaIt does mean under articulation as the spring flattens the axles will move further forward.
Front Suspension problem!
Re: Front Suspension problem!
- TomBod08
One more thing! My sump is leaking oil, think I need a washer for it. Has anyone else had problems with it?
One life. Live it....With a Suzuki
- TomBod08
What part of Huddersfield do you live in?Ladaman wrote:I'm only in Huddersfield. I can help if you want.
Might just need nipping up. Failing that when you do an oil change next just take the sump plug and washed to any motor factors. They usually have a load of various sizes you can match it too.
- TomBod08
Dammit! Just changed the oil as well, then about a week after I noticed the leak
You can undo it a little and then wrap some PTFE tape around it and tighten it back up.
That's what I did last time I changed the transfer box oil and it leaked a little.
- TomBod08
Did it work? I would imagine it still seeping through and eroding over time.
- Ladaman
- Suzuki Guru
TomBod08 wrote:What part of Huddersfield do you live in?Ladaman wrote:I'm only in Huddersfield. I can help if you want.
PM Sent.
Worked fine, been like it for yearsTomBod08 wrote:Did it work? I would imagine it still seeping through and eroding over time.
But it doesn't get anywhere near as hot as an engine, but ptfe is rated to "260 degree C" continuous use
And next time your get probably get a new washer.
I just wrapped it around a few threads, more like string than tape, if you get what I mean.
- TomBod08
Will give that a try then, definitely a cheap option cheers
