Transfer box mounts
Rambo416
Re: Transfer box mounts
Post by Rambo416 » Sun Sep 15, 2013 10:10 pm
so this was how i fitted them washer at the bottom and washer at the top
thanks again
Post by Jordi » Sun Sep 15, 2013 10:18 pm
Should be like this.
Rambo416
Post by Rambo416 » Sun Sep 15, 2013 10:20 pm
ahi thank you Jordi ill let you know how that goes cheers
Post by ScottieJ » Sun Sep 15, 2013 10:48 pm
Sj410red wrote:I've just had a re-mod on the mounts I've added a 1/2 inch poly bush top n bottom, what do u think?
That's spot on! Only extra thing I would do is use some large washers at the top and bottom of the bolt to stop any chance of the bolt head/nut pulling through one of the outer bushes.
Post by Jordi » Sun Sep 15, 2013 10:58 pm
If i remember i'll photos of mine when i'm home.
Rambo416
Post by Rambo416 » Sun Sep 15, 2013 10:58 pm
kk yea got some large washers on there now
swap them round and wire up rear lights then test run
Sj410red
Post by Sj410red » Mon Sep 16, 2013 12:00 am
Scottie...You can't see in the pic but there are washers on top and bottom under the spring washer but they are compressed into the bush, they are about an inch in diameter, just not quite the size of the bush
3" calmini lift springs
6" shackles
Rough Country Shocks
Z bar
32mm spacers
Aisan free wheeling hubs
Roll bar
Snorkel
K&N air filter
Poly bushes all round
Front Diff guard
Post by ScottieJ » Mon Sep 16, 2013 10:09 am
:doublethumbs: ah yes I can just see the edge of the bottom one now I've looked harder. Spot on :doublethumbs:
Sj410red
Post by Sj410red » Mon Sep 16, 2013 4:49 pm
Thanks Scottie, so you think there ok then, saved a bit to which helps!
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
Post by Darrell » Mon Sep 16, 2013 5:27 pm
They look fine, just like what llama4x4 sells. :thumbup: I see they have compressed a little, so at least they have some give. I had visions of poly-bushes being too hard.
I would keep an eye on the nuts coming loose, but if they do just bung some nylocks on.
llama4x4 tranfer case mounts.jpg (94.31 KiB) Viewed 5579 times
