Throttle cable n
Throttle cable n
Just got my engine sittin in place ready for welding and was gunna start connecting things up and the throttle cable is short do i need a vit one or a sj413 one ? Also if u are lookin at the pipes from the front am i right that the the pipe on the right goes on the hole next to the bottom rad hose hole and theres a nother pipe that further up that goes to one on the back of the manifold ? Thankss
Re: Throttle cable n
No really sure I understand the question on hoses
But here's the vit layout, just there is a water control valve on the SJ.
- 1600 vit.gif (50.97 KiB) Viewed 6079 times
Not sure if 413 and 410 throttle cables are different but i'm just using a standard Samurai cable fits fine.
I used a standard throttle cable on my 8v and 16v 1600s, both with SU carbs
thanks Darrell big help , aye mite have to get one mine is defo to short will mine be the same setup as carb or different being a spi thanks
is the cable end not supposed to be bolted in that threaded bracket?
yes it is...
Aye av tried it doesnt reach , any suggestions ?
