Throttle cable n
lukey4x4
Throttle cable n
Post by lukey4x4 » Tue Oct 01, 2013 7:06 pm
Just got my engine sittin in place ready for welding and was gunna start connecting things up and the throttle cable is short do i need a vit one or a sj413 one ? Also if u are lookin at the pipes from the front am i right that the the pipe on the right goes on the hole next to the bottom rad hose hole and theres a nother pipe that further up that goes to one on the back of the manifold ? Thankss
Re: Throttle cable n
Post by Darrell » Tue Oct 01, 2013 11:39 pm
No really sure I understand the question on hoses :oops:
But here's the vit layout, just there is a water control valve on the SJ.
1600 vit.gif (50.97 KiB) Viewed 6081 times
Post by Jordi » Wed Oct 02, 2013 11:34 am
Not sure if 413 and 410 throttle cables are different but i'm just using a standard Samurai cable fits fine.
Post by twiss » Wed Oct 02, 2013 11:37 am
I used a standard throttle cable on my 8v and 16v 1600s, both with SU carbs
lukey4x4
Post by lukey4x4 » Wed Oct 02, 2013 4:10 pm
thanks Darrell big help , aye mite have to get one mine is defo to short will mine be the same setup as carb or different being a spi thanks
lukey4x4
Post by lukey4x4 » Wed Oct 02, 2013 4:57 pm
What yas recon
lukey4x4
Post by lukey4x4 » Thu Oct 03, 2013 6:12 pm
What yas recon
Post by ROBBIE » Fri Oct 04, 2013 10:13 am
is the cable end not supposed to be bolted in that threaded bracket?
Post by twiss » Fri Oct 04, 2013 11:34 am
yes it is...
lukey4x4
Post by lukey4x4 » Fri Oct 04, 2013 4:23 pm
Aye av tried it doesnt reach , any suggestions ?
