Kiwizook's resto
Re: Kiwizook's resto
got all these bits today new transfer box mounts, transfer case lever boot, and new crank shaft bolt.
also had a look at the exhaust, and found this
I'll try to find a new splitter that fits, and weld in a new splitter. one more thing to add to the list It's not a question of how much you spend on your suzuki, but when your money will run out
so started with this
cut the broken bit out
go these
and managed to do this
the welder wasn't going well, but after I had it set up right, I started over again, and I'm quite happy with it now. just have to join the two halves under the wagon now, and weld them togetherIt's not a question of how much you spend on your suzuki, but when your money will run out
- dazerede
That looks better all u have to do naw is fit the cherry bomb on the end and that will be sweet
4” calmini lift kit
4” calmini lift kit
I'll be keeping the standard muffler on it for now, as it has to go through a re-vinning process, and they might not like a cherry bomb on there. I will eventually put a straight through with a cherry bomb on it though, more noise than power
- turbo-tom
More noise then you can shake a stick at.i likekiwizook wrote:more noise than power
Tom
Ford Fiesta ST
Ford Fiesta ST
- dazerede
Haha I like that more noise than power
4” calmini lift kit
4” calmini lift kit
alright then. got monday off as it's labour weekend. I've just set the welder up with 0.6mm wire, got plenty of gas, weld through primer and sheetmetal. you all know what that means
Your coming round mine to repair all my bodywork?
unfortunately that won't work in a single day, I could do if I had more days off
Guess you must be plating, patching and welding yours then.
