parasource rear wheel bearings double seal?
chan
Post by chan » Thu Dec 17, 2009 12:34 am
http://cgi.ebay.co.uk/SUZUKI-SJ-REAR-WH ... _984wt_939
take a look at that.
i want to get 2 new rear wheel bearings but i dont really want to get them from parasource as im not keen on the company but i cant find these double seal bearings anywhere else.
has anyone used these?
carnut
Re: parasource rear wheel bearings double seal?
Post by carnut » Thu Dec 17, 2009 6:59 pm
if you take the number off the bearing,, then contact a bearing supplier, they can then match up the bearing for you.. i used to use avon seals nr weston-super-mare. plus loads cheaper!!
andy
Post by ScottieJ » Thu Dec 17, 2009 7:22 pm
What a load of crap! all the rear wheel bearings i have ever bought are fully sealed! you still need the inner seal! just get a bearing kit from you're local motor factors! the only reason the inner seal will fail anyway is because the bearing has failed. in a bearing kit you get a new inner seal.
chan
Post by chan » Fri Dec 18, 2009 1:11 am
thanks alot for the heads up! thats the last time i even look at anything associated with parasource!
how much should i be looking to pay for a pair of real wheel bearings? mine are shot!
:mrgreen:
ferris
Post by ferris » Fri Dec 18, 2009 9:34 am
I got mine from this place. They seemed ok. About £32 each, and im pretty sure that came with the oil seal. But as was said before it would still be cheaper from a proper bearing supplier.
http://www.japanese4x4spares.co.uk/index.html
