i have a wierd squilling noise from the rear axle
Re: i have a wierd squilling noise from the rear axle
Post by donkeychomp » Wed Dec 04, 2013 11:07 pm
If a UJ does go pop you can always put it in 4WD and drive home in 2WD if you get my drift...that happened to me once. Was in front wheel drive only but it lasted ages before I got a new UJ.
Post by dan_2k_uk » Thu Dec 05, 2013 7:51 am
Jordi wrote:Another 1000miles in that.
Brand new bearing then.... :D
Post by ROBBIE » Thu Dec 05, 2013 8:44 am
Problem was the stereo was at full and I could still hear it squealing ;)
Post by ScottieJ » Thu Dec 05, 2013 9:31 am
Probably a dry UJ, take the prop off and investigate, most likely will be the axle end. I've got this at the moment too, i'm waiting for it to explode :hahaha:
Hence my wanted add for a new prop as there's not much point replacing a UJ on a crap propshaft.
dazerede
Post by dazerede » Thu Dec 05, 2013 9:51 am
Just looked and there is a little bit of play nothing much
Sprayed it with wd40 and it still is making the noise
I will take prop of when I finish college and investigate it I.might have a spare rear prop I will pop on
4” calmini lift kit :)
Post by ScottieJ » Thu Dec 05, 2013 10:14 am
dazerede wrote:Just looked and there is a little bit of play nothing much
there could be no play at all but it could be dry and stiff. wd40 will not make any difference, UJs need grease.
dazerede
Post by dazerede » Thu Dec 05, 2013 10:25 am
Ok I.will fill it with grease and go from there
Before I.sprayed with wd 40 the end of the prop looks oily I thought it was the pinion seal from the diff but the diff oil hasn't dropped so the grease has leakedout and become dry
dazerede
Post by dazerede » Thu Dec 05, 2013 10:27 am
This is a pic before I sprayed wd40 on.it so it must of leaked out as you can seethe grease has sprayed every where underneath
