1.6 8v spi quickie
1.6 8v spi quickie
Post by andyrew » Mon Dec 09, 2013 7:49 pm
Im collecting a spi 8v lump from a breaker vitara
Ive got most of the lump mounts etc etc
Is there anything else needed for the spi engine that id need
From the vitara? Any electronic bits required?
Im on the understanding that I would just need a 12v fuel pump for
It to work?
Re: 1.6 8v spi quickie
Post by dan_2k_uk » Mon Dec 09, 2013 10:23 pm
If you wanna stick it on a SU or webber you need nowt but a leccy pump.
The gearbox bolts are handy if you are planning on mating to a 1300 gbox.
Rhinoman
Post by Rhinoman » Tue Dec 10, 2013 10:29 pm
If you're not SPI already then you need the wiring loom and ECU, get the bracket with the relays on too. You will also need the inlet and exhaust manifolds with sensors and the MAP sensor from the bulkhead. Ideally get the VSS from the speedo too.
Post by andyrew » Tue Dec 10, 2013 10:33 pm
Cheers dudes
SU it is :D
Post by dan_2k_uk » Tue Dec 10, 2013 10:41 pm
andyrew wrote:Cheers dudes
SU it is :D
Good lad :thumbup:
