Painting with a roller, loads of bubbles in paint...
- timwilks13
- SCUK Website Padawan
Re: Painting with a roller, loads of bubbles in paint...
You wanna be using plasti-dip mate, best stuff imo.
If you want it reasonably decent but can't spray it
Flat it back with and give it a good few coats with the mix quite thin
Flat that back with 1500 wet and dry (soak the paper in
Water and fairy for around 20 mins beforehand) then cutting compound
It. Or you could lacquer onto the flatted off red.
Look up rustolem paint jobs for some ideas and tips
thanks for the advice, so wet sand it inbetween each coat? and final coat wet sand it with fairy liquid and then laquer it?
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Yea you can do. The smoother the paint the easier the flatting.
Just give a section a try before doing the whole anus.
Youd be supprised what can be polished up with some effort.
Slightly different but this was sprayed in my workshop
And the laquer resembled something similar to bubble wrap
With dead bugs and dust in it. I thought it was a redo job
But a friend of the owner flattened and polished it up lovely
- 20131117_210012.jpg (2.51 MiB) Viewed 5635 times
oooh i do like S15's haha now that you say it i would say my paintjob looks like bubblewrap haha
ill do my bonnet first and see if i can get it to come up nice, will need a couple more coats anyway, not in this weather though, its way too cold the paint will just run like water lol
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
- donkeychomp
I know a lot of people use rollers but you can get amazing finishes with rattle cans, but it's all in the prep work! Get the body work clean and smooth and you should have no problems.
This is true. Ive had some great results with rattle can paint. Again itsdonkeychomp wrote:I know a lot of people use rollers but you can get amazing finishes with rattle cans, but it's all in the prep work! Get the body work clean and smooth and you should have no problems.
All in the prep and being patient.
Im learning to paint carbon fibre at the moment. Its a pain in the arse.
Very very difficult material to work with.
Plasti cote or stuff called frost it fantastic chek out the vids of the stuff
1994 sj 413 sierra
cheker plate door cards
cd players
asin free wheeling hubs
99% rust free
alloys
bukets
some leaks here and there
cd players
99% rust free
alloys
bukets
I've seen plasti dip which I might get some black to try in my wheels cause if I don't like it a can always peel it off
I'll have a go at getting the body painted when it starts to warm up again, I've got a 5l tin of red paint so I'll get it rollered and brushed and see if I can get a smooth finish
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
My Sj is an offroader, couldn't really care less about the paint finish as it gets scratched and dented on a regular basis, I just touch it up with a brush nowadays
Also it does depend on what type of paint you use, the synthetic paint that mine is painted with actually comes out very smooth when applied with a brush.
