rock sliders ideas
- dazerede
rock sliders ideas
I.need to fit Rock sliders to my zook I.like the idea of scottie jwhat size metal is that 4x2 looks to big Is it 3x2 or something scottie as I want to copy your idea unless other people have better ideas
I am planning on bolting my cage to it once I make a cage
- IMAG0700.jpg (43.04 KiB) Viewed 8457 times
4” calmini lift kit
4” calmini lift kit
- dazerede
Re: rock sliders ideas
Anyone
4” calmini lift kit
4” calmini lift kit
Not sure what size steel Scottie used something 50x80 with a 3/4mm thick wall would be ok. The important part is to reinforce or sleeve chassis where you weld them on.
- dazerede
Ye I will get some steel and strenghten the chassis and then weld it to the steel on.the chassis
I will copy scotties idea savor looks good
Scottie where has your sills gone dude
4” calmini lift kit
4” calmini lift kit
- turbo-tom
if you go through his build thread he has cut them out and "tucked" them up.
Tom
Ford Fiesta ST
Ford Fiesta ST
- dazerede
Ok chears tom I.had a quick flick threw again lol love going throught his build thread
I will pop up metal place tmoz and go from there I will proberly make the rock sliders and then ask my mate to weld the strenghen plate on.the chassis as I want it done properly and he is a good welder what size is best for it
4” calmini lift kit
4” calmini lift kit
I'm not sure of the dimensions but I would sleeve the outside of the chassis with some 3mm thick "U" channel.
Needs welding carefully, if you can wear a face mask / dust mask type with an air filter as the fumes that come off welding to a galvanised chassis are toxic.
- dazerede
Ok Ye just read scotties build he used 5mm thick spreader plate for his front shock torents so I will use 5 or 3mm
Jordi chears also what you mean u shape
Do I need to cut the spreader plate as a shape of a U so it is welded to the chassis in the middle aswell if you understand
4” calmini lift kit
4” calmini lift kit
Same as in Tom's picture. Instead of just welding a plate to the side of the chassis it will wrap around it, nice and strong
