sj410 manual fuel pump oil leaking
bedron
Post by bedron » Fri Jan 03, 2014 3:35 pm
hi guys just wondering whats the best sealer to use for fuel pump on my sj410 project. i bought new pump cleaned area and fit new gasket and there is oil leake ,stripped back fitted another new gasket with tiger seal and there is still oil leak :er:
Re: sj410 manual fuel pump oil leaking
Post by turbo-tom » Fri Jan 03, 2014 3:40 pm
hmm sounds like you have used a pretty much similar way like you would use instant gasket. possible chance the surface possibly might of warped, That's the worse that could happen.
id give the two surfaces a proper good clean up and try again. if not use an old cereal box
Post by Jordi » Fri Jan 03, 2014 4:34 pm
turbo-tom wrote:hmm sounds like you have used a pretty much similar way like you would use instant gasket. possible chance the surface possibly might of warped, That's the worse that could happen.
Old cereal box, what kind of amateur are you? Everyone knows DIY gaskets are made from strongbow cases.
Post by Tramp » Fri Jan 03, 2014 5:06 pm
I don't know what the fuel pump is like on a 410 but on a 413/Sammy sometimes the pump diaphragm starts leaking, the oil comes out of the breather hole on the underside of the pump and causes a few oil drips while running, if it's this it's best to replace the pump,
Post by Darrell » Fri Jan 03, 2014 11:56 pm
Was it a brand new pump ? Only asking after reading this post.
http://forum.suzukiclubuk.co.uk/vi ... =13&t=8597
bedron
Post by bedron » Fri Aug 08, 2014 12:17 am
yes its brand new pump ,im just after putting old one back and leak is still there
