1.3 1.6 inlet manifold
timwilks13
SCUK Website Padawan
Post by timwilks13 » Sat Jan 11, 2014 11:36 am
I have put my 1.3 manifold onto the 1.6 block as it was modded for the su, but noticed the inlet holes are slightly bigger on the 1.6 than the 1.3, will this cause any issues?
trotter
Re: 1.3 1.6 inlet manifold
Post by trotter » Sat Jan 11, 2014 11:49 am
Ever so slight power loss but as its a off roaster and not a race car it prob not even noticeable I did same on mine
if in doubt, FLAT OUT!
Post by twiss » Sat Jan 11, 2014 1:15 pm
Yeah it won't make much of a noticeable difference to be honest
Post by dan_2k_uk » Sat Jan 11, 2014 1:24 pm
It will probably only effect the top end if anything.
timwilks13
Post by timwilks13 » Sat Jan 11, 2014 5:07 pm
Of you lot that have done this what fuel pump did you use? Just looking on eBay and there are hundreds to choose from!!
Post by Jordi » Sat Jan 11, 2014 6:16 pm
Facet low pressure pump. 1-4psi I think.
Post by twiss » Sat Jan 11, 2014 9:42 pm
Mines like this... not had any problems with it... ideal psi is about 3.5 iirc
http://www.ebay.co.uk/itm/Facet-12v-Low ... 5d418a293f
Click Here for Ebay Listing
