Peddles
- ianedwards
- SCUK Addict
Peddles
Hi, just wondering, never driven another sj so nothing to compare to.
I've hooked up all my peddles now in the sj, and the clutch peddle is a lot higher than the brake and the go peddle..
Is this the way it is or is some thing up?
Ian.
Ian.
Re: Peddles
My clutch and brake are even but the throttle is lower.
Should be able to adjust the height of the pedal with the cable sheath adjustment.
- ianedwards
- SCUK Addict
Re: Peddles
The brake is where I would expect and the go is a little bit lower
Will have a look, if the brake and clutch are sort of level with each other either mine needs adjusting dramatically or something isn't right.
Cheers for that.
Cheers for that.
Ian.
Ian.
Re: Peddles
The go peddle? What kind of amateur terminology is that? You should know by now..........
It's the loud pedal!
- ianedwards
- SCUK Addict
Re: Peddles
Took a quick pic before I left, you can see the difference between the brake and the clutch
I don't think it's any thing I've done, I'm sure it was like that when I bought it.
I like my terminology (the go peddle ) - mainly because I was in a rush and couldn't be bothered to spell throttle or accelerator
Ian.
Ian.
- donkeychomp
Re: Peddles
This any help
- Pedals.jpg (276.7 KiB) Viewed 5193 times
- ianedwards
- SCUK Addict
Re: Peddles
Nice one, that adjustment bolt bracket behind the clutch PEDAL was bent all over the place, which was fixed when it was out, probably needs setting correctly. cheers.
ill loosen the cable off, correct the pedal and set the cable again. see how that goes.
ok i admit, im not the best at spelling
Ian.
Ian.
- Tramp
Re: Peddles
It's ok, you don't get points for spelling, as long as you get your point across, keep up the good work
