Gearbox leak
george123
Gearbox leak
Post by george123 » Sat Jan 18, 2014 6:23 pm
Hello all! Right I've got a leak from inside the bell houseing of the gearbox I've tried putting gasket maker on in but it still seems to leak through any ideals what els I can try
gp7186
Re: Gearbox leak
Post by gp7186 » Sat Jan 18, 2014 7:26 pm
A leak into the bellhousing will be a seal gone, either the crank shaft seal or gear box input shaft seals which is gearbox out to repair to do it properly
Re: Gearbox leak
Post by Jordi » Sun Jan 19, 2014 10:17 am
Is it engine oil or gearbox oil?
Input shaft seal is easy enough. Gearbox out, half a dozen bolts, refit. About £8 from Suzuki.
Re: Gearbox leak
Post by twiss » Sun Jan 19, 2014 12:35 pm
You can tell because gearbox oil smells like cat piss!!! Lovely!
george123
Re: Gearbox leak
Post by george123 » Sun Jan 19, 2014 10:16 pm
It's gear box oil alright and I took the plate of over the input shaft and it looks like it is leaking from the that does that plate have a gasket on because iv just trye making my own gasket to seal it
Re: Gearbox leak
Post by Darrell » Sun Jan 19, 2014 10:42 pm
The manual says it has sealant. IE liquid/silicone gasket.
I trust the oil seal is OK
