Sj410 starter wiring
- Sj410red
Hi all, I changed my starter today, old 1 had 2 spade connectors on solenoid new 1 has only 1? Any ideas what the other connector is for, it comes from the alternator wiring. Sj starts ok and runs tho.
3" calmini lift springs
6" shackles
Rough Country Shocks
Z bar
32mm spacers
Aisan free wheeling hubs
Roll bar
Snorkel
K&N air filter
Poly bushes all round
Front Diff guard
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
Re: Sj410 starter wiring
The 410 has the black/yellow from the ignition switch to the solenoid but also a connection from the solenoid direct to the coil positive. This supplies 12v to the coil when cranking over.
Hope this is what your referring too.
- 410 Ignition circuit.jpg (168.63 KiB) Viewed 7141 times
Something like this ??
Edited due to inaccuracy on wire colour.
- Sj410red
Yes that's what the old starter is like
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
- Sj410red
So can i just connect the cable to the battery terminal on the solenoid? As there's no other spade connector on the solenoid.
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
Yes, but it needs to go on the large terminal on the solenoid (the one going into the side of the motor, only powered when cranking)
You could use a large ring terminal.
Could you not reuse the old starters connection or is that knackered.
- Sj410red
Looking at the pic you posted is it the bolted terminal or the left spade as I don't have the right spade, sorry I'm not all that clued up on these electrics
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
You need to connect the wire going to the coil here.
Your old one had a spade terminal, but a ring terminal would do.
- st 2.jpg (78.31 KiB) Viewed 7116 times
- Sj410red
Arh,I get you now, yes it's an exposed short cable which goes into motor, yes I will have a look at old starter to see if I can prise off the spade or see if I can buy a circular spade connector, thanks very much for your help, just one more question tho, it starts and runs as it is now so what does this connection do when I connect it?
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
Basically just gives the coil a boost on starting to help get it going. (bigger spark I guess)
That's it really, as you found out it may well start fine without it.
