Getting To The Timing Belt
Rhinoman
Re: Getting To The Timing Belt
Post by Rhinoman » Mon Feb 10, 2014 10:33 pm
One tooth out will have a big effect, you just need to pull the belt off and then rotate the cam a tooth. Its best to mark the belt and pulleys with paint before you start in case you get lost in the middle of the job.
The Bird Man
Timing Belt
Post by The Bird Man » Tue Feb 11, 2014 11:01 am
Quick question to make sure, how many lines on the flywheel after 10 degrees (B.T.D.C) Is 0 degrees (T.D.C) ? Many thanks ;)
timwilks13
SCUK Website Padawan
Post by timwilks13 » Tue Feb 11, 2014 11:59 am
I think 1 line is 2°, mine is 4 marks and 8°btdc, but don't take that as gospel.
The Bird Man
Post by The Bird Man » Tue Feb 11, 2014 12:14 pm
Ahhh this is confusing :S What do you mean yours is "4 marks and 8°btdc" pal ? I was under the impression that I had to get it at 0° to be TDC ?
Ladaman
Post by Ladaman » Tue Feb 11, 2014 12:45 pm
For cam timing you want the crank at TDC
The 8 - 10 or what ever number BTC is for ignition timing, so of no importance for changing a cam belt.
The Bird Man
Post by The Bird Man » Tue Feb 11, 2014 1:23 pm
So am I right in thinking to get number 1 piston at top top dead center, I'll get the 10 degrees flywheel mark aligned with the pointer on the bell housing then carry on turning the crankshaft until the fith line on the flywheel past 10° is aligned with the pointer as each line is 2°, it should be at 0° (T.D.C) ? The rotor arm should also be aligned to the 1 spark plug terminal. Thanks for your patients :D
Rhinoman
Post by Rhinoman » Tue Feb 11, 2014 6:24 pm
Is the timing belt cover damaged? from what I recall it should have '0' marked on it. The Vit is marked 0, 10 and 20.
The Bird Man
Post by The Bird Man » Tue Feb 11, 2014 6:40 pm
The only marking the cover has on it is an arrow head at 12 O'clock which should correspond with the cam sprocket if in time :) Which I'm not 100 % certain it is.
Post by Darrell » Tue Feb 11, 2014 7:33 pm
From the 410 workshop manual.
I don't think many (if any) people bother to slacken all the valves off.
The Bird Man
Post by The Bird Man » Sat Feb 15, 2014 12:49 pm
Morning folks, right after many hours of head scratching and Suzuki club forum scanning. I've figured out that my engine is firing on cylinder four instead of number one ( I think ?? ). Fly wheel mark is at T.D.C and all the sprockets are in line with the timing marks on the cover and the rotor arm is pointing at number 4 on the dizzy cap :D
