413 owners beware!
413 owners beware!
Post by donkeychomp » Mon Feb 17, 2014 11:17 pm
Got a couple of engine blocks from Andyrew (ta matey!). Plan is to get them all cleaned and make a coffee table!
But I did see this...get that rocker box cover off and check yours!!
Re: 413 owners beware!
Post by Jordi » Mon Feb 17, 2014 11:24 pm
Common fault.
Probably not a bad idea you reminded us again about it.
Not sure if the 1.6s do something similar?
Post by andyrew » Mon Feb 17, 2014 11:28 pm
Ohh yes. That was a low mileage engine Suppsedly.
Scottie may remember the call regarding water dripping
From the sump :hahaha:
Its also why the rockers are clean because water was shooting
Out the oil ways!
Post by donkeychomp » Mon Feb 17, 2014 11:33 pm
Yep Jordi my Vit 1.6 had the same problem...loctite sorted that! Glad I didn't lose a whole screw though...
muddymesser
Post by muddymesser » Mon Feb 17, 2014 11:38 pm
i lost a few from my 1.3 n robbed a few from a 1.6 from the scrappy n they were loose . . . i used a punch to put in a bit of a dent so they wouldn't come loose . . . they were all still tight when i swapped my engine about 10,000 mile later
Post by ScottieJ » Mon Feb 17, 2014 11:50 pm
Happens on all the F and G series 8vs I just torqued up all mine the other evening and 2 were starting to back out.
Post by dan_2k_uk » Tue Feb 18, 2014 8:07 am
I've also experienced 2 heads where I couldn't get them out for love nor money! :screwy:
Post by Tramp » Tue Feb 18, 2014 8:17 am
Is it worth replacing them for Allan head c/sunk screws? I don't really trust posi-drives,
kiwizook
Post by kiwizook » Tue Feb 18, 2014 8:58 am
I had the problem on my f10a that I couldn't get them out however hard I tried. a client of our's is a maintenance engineer at the local printing press, and he removed for me at work, he had to use a oxy torch to get them out. the aluminium melted slightly around the screws, shows you how much heat he had to use! the head was already scrap, I just needed the parts of it. I have replaced them with allen head ones, and the guy supplied these for me, all for free, he's a great guy
Rhinoman
Post by Rhinoman » Tue Feb 18, 2014 8:54 pm
From what I recall there was a TSB issued that says to stake the heads. I'm pretty sure that's its a Phillips head and not a Pozi-Drive.
