leaky transfer box
bencotterell
leaky transfer box
Post by bencotterell » Wed Feb 26, 2014 4:02 pm
hi my sj has been leaking oil out transfer box where the lever goes in is it a seal or will it be a case of tightening it up if its a seal i need where can i get one from? thanks Ben
ferris
Re: leaky transfer box
Post by ferris » Wed Feb 26, 2014 4:55 pm
There should be a rubber gator that covers where the lever go's in.
Post by ROBBIE » Wed Feb 26, 2014 7:07 pm
ferris wrote:There should be a rubber gator that covers where the lever go's in.
To add that can go hard, if not used for a long time and split
dazerede
Post by dazerede » Wed Feb 26, 2014 7:13 pm
Ye I noticed on my rocklobster t box mine isn't on properly and it is leaking oil a bit and is f ing hard to get on and can't get it on any suggestions
4” calmini lift kit :)
Ladaman
Post by Ladaman » Wed Feb 26, 2014 9:03 pm
Use a small screw driver like a tyre lever, and slowly work around it. That should lift it on.
dazerede
Post by dazerede » Wed Feb 26, 2014 10:22 pm
I had a spare 2 mins today and I couldn't get it on so I will warm it up a bit and go from there
bencotterell
Post by bencotterell » Fri Feb 28, 2014 12:50 am
Ideal thanks for the reply's will have to give it ago when get spare 5 mins hopefully can sort it. Should it be leaking out when just moving it few feet back and forward in mates garage?
Post by Darrell » Sat Mar 01, 2014 12:35 pm
I was just wondering what peoples opinions are on this.
There is no seal , just an outer gaiter.
Does the shifter bush act as a seal or does the slot on the shifter allow oil past ????
I know I've seen quite a few pics of the bush breaking up.
I know this is not a proper seal but it's only got to stop oil splashing up.
I dunno :er:
Post by ROBBIE » Sat Mar 01, 2014 1:10 pm
Think its only the gaiter that dose the job, when mine split water got in and filled the box. then a lovely grey and pink cream substance started leaking out :lol: :oops:
bencotterell
Post by bencotterell » Mon Mar 10, 2014 10:16 pm
That could be the reason myne was leaking going to try and change oil on it tmos morning where can i get a replacement gaiter from?
