leaky transfer box
- bencotterell
leaky transfer box
hi my sj has been leaking oil out transfer box where the lever goes in is it a seal or will it be a case of tightening it up if its a seal i need where can i get one from? thanks Ben
Re: leaky transfer box
There should be a rubber gator that covers where the lever go's in.
To add that can go hard, if not used for a long time and splitferris wrote:There should be a rubber gator that covers where the lever go's in.
- dazerede
Ye I noticed on my rocklobster t box mine isn't on properly and it is leaking oil a bit and is f ing hard to get on and can't get it on any suggestions
4” calmini lift kit
4” calmini lift kit
- Ladaman
- Suzuki Guru
Use a small screw driver like a tyre lever, and slowly work around it. That should lift it on.
- dazerede
I had a spare 2 mins today and I couldn't get it on so I will warm it up a bit and go from there
4” calmini lift kit
4” calmini lift kit
- bencotterell
Ideal thanks for the reply's will have to give it ago when get spare 5 mins hopefully can sort it. Should it be leaking out when just moving it few feet back and forward in mates garage?
I was just wondering what peoples opinions are on this.
There is no seal , just an outer gaiter.
Does the shifter bush act as a seal or does the slot on the shifter allow oil past ????
I know I've seen quite a few pics of the bush breaking up.
I know this is not a proper seal but it's only got to stop oil splashing up.
I dunno
I dunno
- p3.jpg (34.16 KiB) Viewed 6788 times
Think its only the gaiter that dose the job, when mine split water got in and filled the box. then a lovely grey and pink cream substance started leaking out
- bencotterell
That could be the reason myne was leaking going to try and change oil on it tmos morning where can i get a replacement gaiter from?
