sj has a cold.
- timwilks13
- SCUK Website Padawan
sj has a cold.
I can't go up hills or rev too high without all manner of coughing and spluttering. Timing is spot on, right needle and spring in carb, carb tuned accordingly and two new fuel filters, anything I might have over looked? Carb adaptor isn't freezing up either.
- Edweird
Re: sj has a cold.
Mine coughs and splutters when it's cold. I did have a problem with air starvation once when the old air hose gave up and was suffocating the engine. Also, years back when I first passed my test, the fuel system was full of little rust flakes, which completely blocked the fuel filter and would also sometimes block the pickup in the tank.
Sounds like it's being starved of something to me, OR maybe you're losing a cylinder at high revs. Have you cleaned and gapped your plugs recently? If the gap is too big they can drop off at high revs.
- timwilks13
Re: sj has a cold.
Checked gaps, all fine, its just got no power, at idle I can rev it as high as she wants to go, its when there's a load behind her it just has no pull, I'm going down the gears the further up a hill I go, very frustrating!!
- timwilks13
Re: sj has a cold.
Erm just took the air intake off and my carbs full of mucky gunky fuel...that's not normal I don't think?!
- timwilks13
Re: sj has a cold.
The oil cap is that colour too!!
- timwilks13
Re: sj has a cold.
And the rocker cover.
- IMG_20140304_215049659.jpg (1.35 MiB) Viewed 6318 times
Re: sj has a cold.
That dosent look good
- donkeychomp
Re: sj has a cold.
The dreaded sludge...in most cases that's the head gasket gone. Not too hard a job to tackle. Hope you get it all sorted.
Re: sj has a cold.
You've probably got a hose on wrong, Facebook time
- Sj410red
Re: sj has a cold.
Looks like the head gaskets blown to me! That would be why your losing power to.
3" calmini lift springs
6" shackles
Rough Country Shocks
Z bar
32mm spacers
Aisan free wheeling hubs
Roll bar
Snorkel
K&N air filter
Poly bushes all round
Front Diff guard
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
